07-06-2014 13:50
07-06-2014 13:50
Just started using fitbit. Trying to figure out how to get most on features. I am also doing weight watchers... is there a way to count points in place of calories?
07-06-2014 16:54
07-06-2014 16:54
Not that I've seen, but I heard from Weight Watchers that integrating the two could be coming soon. I'm also on Weight Watchers. ![]()
07-07-2014 15:39
07-07-2014 15:39
I just track at WW
Wendy | CA | Moto G6 Android
07-09-2014 10:24
07-09-2014 10:24
it would be nice to track the step some how...in ww points...
07-11-2014 14:42
07-11-2014 14:42
@danajoy If you want to track your Steps at WW then go to the AP tracker scroll to the bottom and there is a place to add steps
07-15-2014 09:32
07-15-2014 09:32
Also a Weight Watcher member here.
When I started using Fitbit I stopped tracking points and started using My Fitness Pal instead.
MFP syncs with Fitbit and you can set it up to match your WW goals.
I've actually lost more weight using it than when I was tracking just points. The initial few days were a little difficult, but now it's much easier to use.
07-19-2014 11:49
07-19-2014 11:49
If you measure your stride length, you can use WW etools to change your fitbit strides into Activity Points.
Go to Track Activity. At the very bottom, it says Quick Add. Next to that is the tab for Add Steps. Click on Add Steps and you can enter your steps. You do have to measure your stride length initially for etools to calculate your Activity Points.
I use my fitbit graph to figure out which steps were actually part of my workout or my activity. I total up all the yellow and green bars and then enter those as my steps.
07-22-2014 19:37
07-22-2014 19:37
07-25-2014 14:47
07-25-2014 14:47
I use MyFitnessPal also, but I just started Weight Watchers. So if you're not tracking points, what are you tracking for WW? I've been tracking my food and then at the end of the day calculating the points. Is there a better way to do this? I'm only on week 4 of WW but I have lost a couple of pounds.
Rily
Best Answer07-25-2014 16:41
07-25-2014 16:41
Best Answer08-06-2014 08:31
08-06-2014 08:31
I learned this later on one of the WW forums. You can change your Fitbit calories into points. 80 or 100 calories is equal to one Activity Point. That means you don't have to use etools on a computer to track steps. Instead, just take the change in calories before and after you work out. Divide that number by 80 or 100 and that should give you your activity points.
