07-08-2014 16:50
07-08-2014 16:50
So I got myself fitbit flex instead of more expensive and less featureful mywellnesskey.
I've "synced" mywellness website with fitbit, and works fairly well. However the data is pushed one way: from fitbit to mywellness. Ideally I'd like to see mywellness workouts in the gym to be synced as activities into fitbit.
Anybody knows if that's possible? Does fitbit need to code that? or should mywellness or 3rd party to do that
07-08-2014 21:58
07-08-2014 21:58
I’m not familiar with mywellness, but from what I can tell they want you to use their system for monitoring your fitness. Fitbit will allow them to post activities to you Fitbit account, but I speculate that it doesn’t fit their business model. You would need to let Technogym/mywellness that you want that feature.
Your saving grace would be if mywellness posts your data to any other service (i.e. myfitnesspal), Fitbit may be able to get the activity record via that other service.
12-31-2014 00:16
12-31-2014 00:16
What Xnox said.
12-31-2014 11:46
12-31-2014 11:46
@SunsetRunner MyWellness uses the Fitbit open API to integrate their software and pull your data from the Fitbit servers. They control what is sync'd and whether it is one way or two way. You would need to press them on the issue. Fitbit has no control over it.
01-02-2015 16:09
01-02-2015 16:09
01-03-2015 02:53
01-03-2015 02:53
01-18-2017 08:37
01-18-2017 08:37
Hey xnox,
I've started using a flex 2 a couple of hours ago..
I'm having the exact same question.
Have you found a way to push your mywellness stats to your Fitbit account?
Thanks!
01-21-2017 12:19
01-21-2017 12:19
Hello There, I also want to export the mywellness data into fitbit. I can't seem to find a good solution for this. Also a work around can't be found. Please help?
10-20-2017 12:12
10-20-2017 12:12
Surely this is not rocket science, mywellness is in my gym I use the scales for composition what this data in Fitbit account. I don't use mywellness cloud for anything else.
Mywellness pulls data from Fitbit but Fitbit does not do the other way !
is there an answer ? Has anyone done it ?
