04-06-2014
17:33
07:24
AngelaMa
04-06-2014
17:33
07:24
AngelaMa
Is there any way to sync fitbit with my movile weight watchers app so that I don't have to log activity and calories in both locations?
If you're doing WW, I wouldn't bother logging food here. They are two different plans and there isn't much reason to try to do both. If for some reason you want to see Fitbit's charts of your calories in vs. out and you count points all day, a rough estimate of calories is points times 40. You can log that as one line item 'custom food' and see all the charts.
There is an easy to get WW credit for your steps in the mobile app. There is a Log Steps tab, I think it's called. You can wait a few days and log several totals at once and it just takes a second and adds to your APs.
Best AnswerWhat I did was just created a food called WW Points and gave them 50 cal per point. Then I look at my WW points and then add 1 point for each fruit I eat. For example. I eat 26 Point plus 10 Fruits/Veg then I would enter into Fitbit Log WW Points of 36 which is 1,800 Cals. For me it has be very accuarate; however, you may need to adjust how many Cal per Points you use.
I now put in 36 WW Points for the entire week then Fitbit App tells me if I am over or under which helps if I want to eat additional Points. Plus its easier to adjust WW Points in App too.
On the WW side, I only enter the number of steps for the day from FitBit and nothing else.
Hope this helps,
Best AnswerThis is the answer I just got to link mine... I am in the US and have a Flex
Please follow the steps below to link your fitbit device to your Weight Watchers eTools.
1. Instruct the member to log into their eTools account.
2. From the My Plan menu, select the Activity link under the FAQs heading
3. Scroll down the FAQ page until you see Which activity-monitoring devices and apps can sync with Weight Watchers?.
4. Select the You can find a list of our supported devices and apps here. link.
5. Choose the activity monitoring device to be linked to Weight Watchers.
Enter the Email address and Password associated with the Fitbit account.
NOTE: If the member has not set up their Fitbit account yet, they can do so by selecting Create a New Account on the right side of the page.
Best AnswerHere is the steps to link the Fitbit
Best AnswerI am having the same issue--Fitbit was syncing with WW app beautifully, but after update, it is not. Not sure if it is a WW issue or Fitbit issue. Hopefully, will get it resolved soon!
@jbg17200 wrote:This is the answer I just got to link mine... I am in the US and have a Flex
- Click the Continue button
- Click the Allow button.
do u do this on the weight watchers page or the fit bit page?
You will need to do that from your Weight Watchers page.
Best AnswerThanks for your reply, jdagati. I have tried everything, including deactivating and reactivating, deleting and reloading fitbit, signing out of both progams, and it still is not working. I have contacted weight watchers and fitbit, but have not heard anything back.
Weight Watchers is the only one who can help you. But try Unlinking and reling again. Its been working for a week now
Wendy | CA | Moto G6 Android
Best AnswerHello All
Just got a fitbit flex today as a present. I am with Weight Watchers and also want to make the most out of my fitbit dashboard but don't want to need to input my food intake into both WW and fitbit. I have synced my WW a/c with my fitbit a/c.
I have searched the forums but not certain whether the food I enter onto my WW a/c will sync with the calorie intake on my fitbit a/c?
Please help clarify!
Thanks
TW
Best AnswerHere it is the end of February and I have been trying for several weeks to get my fitbit weightwatchers link to work. It worked for the last few days, and now its the late afternoon and no activity points. I have just disconnected and reconnected which sometimes works. I have complained to both fitbit and weightwatchers and boty say it is a "known problem" and they are fixign it, repair date unknown. Seems pretty low priority. Apple watch, enayone?
