A little background before I ask my question. I had a versa 3 and bought 3rd party bands. After about a month the bands wore out the connection point on the Versa 3, the band popped off and slingshot off my wrist in a parking lot, shattering the screen.
I have now purchased a Versa 4 and the band, like the stock band of the Versa 3, gives me a rash. I am looking for recommendations from all of you seasoned folks as to where I can buy a 3rd party band, preferably a band that does not buckle.
Thank you, in advance, for your advise.
Best AnswerHello @lavascion Before you look elsewhere, did you see the Hook & Loop band in the Fitbit Store? Not silicone, no buckle. As far as third party bands go, I just have a comment. Some users who upgraded to a Versa 4/Sense 2 said that their third party bands from their Versa 3/Sense didn't fit well. Or fit at all. Look for a verified review of any third party band with a Versa 4.
Laurie | Maryland
I have found with my Versa4 to occasionally remove the watch and clean inside the straps.
Dead skin accumulates with prolonged wear.
I have been using the Versa4 Smart watch continually since early last year.
The original band.
My experience only.
I hope you find this helpful.
8YL57P Jogger.
Best AnswerI actually had not seen the hook and loop one on the fitbit site. I must have missed it entirely. That is exactly what I want. Had i seen that, I never would have made this post.
Thank you so much for pointing it out.
