05-20-2023
07:54
12:00
ManuFitbit
05-20-2023
07:54
12:00
ManuFitbit
Thanks to Fitbit for putting the feature in place to begin with it is immensely helpful but if you could see your way clear to add in the capability of printing, exporting or sharing the data it would be fantastic and greatly appreciated
Moderator edit: clarified subject.
05-20-2023 08:02
05-20-2023 08:02
Hello @Mariastephens and welcome to the Community. Please vote for and leave a comment on this request in the Product Feedback forum. It's a shame that Fitbit didn't include this feature when it was introduced.
Laurie | Maryland
05-20-2023 08:02
05-20-2023 08:02
Laurie | Maryland
05-20-2023 08:28
05-20-2023 08:28
05-24-2023 14:31
05-24-2023 14:31
According to Fitbit help, "Within each result, tap Export a PDF for your doctor to download the report. You’ll receive a notification when your report is ready. "
I cannot find anywhere in the results on the app where it says Export a PDF for your doctor.
05-24-2023 14:41
05-24-2023 14:41
I was hopeful but i can't find anywhere a way to export pdf
05-25-2023 01:58
05-25-2023 01:58
Open the Fitbit app on your phone - tap on the discover tab (on the bottom navigation bar) - tap on "Heart rhythm assessment" - "view results" - tap on one of the tests - "Export a PDF for your Doctor" - Continue the steps - When a notification pops up tap on "View it" - you should then be able to select where to save the PDF.
I've made a short video that may help you figure out the steps.
05-25-2023 08:38
05-25-2023 08:38
Thanks for the information. But, I am looking for a way to print or pdf Irregular Rhythm Notifications. The Recent Notifications show "Signs of atrial fibrillation" during my sleep.
05-26-2023 02:01
05-26-2023 02:01
@NoWord In that case it's not possible. I believe the irregular heart rate notifications are just there to serve as a prompt for the user to take a manual ECG. Obviously in your case that would be difficult if it's happening during sleep.
