Allow Afib to export, print and share data
ANSWERED
Thanks to Fitbit for putting the feature in place to begin with it is immensely helpful but if you could see your way clear to add in the capability of printing, exporting or sharing the data it would be fantastic and greatly appreciated
Moderator edit: clarified subject.
1 BEST ANSWER
Accepted Solutions
Hello @Mariastephens and welcome to the Community. Please vote for and leave a comment on this request in the Product Feedback forum. It's a shame that Fitbit didn't include this feature when it was introduced.
Laurie | Maryland
7 REPLIES 7
Laurie | Maryland
😊 they might not have realised the extent to which this utility would be
so important to the public. Myself i have afib, i have already had an
ablation imagine my surprise when Fitbit informed me that i was having afib
symptoms, i went to the hospital and they kept me 3 days so thank you
Fitbit.
Hopefully out of the tremendous need to export the data expressed by a
grateful community they will implement the ability to export, save to a
file or something
Maria
According to Fitbit help, "Within each result, tap Export a PDF for your doctor to download the report. You’ll receive a notification when your report is ready.  "
I cannot find anywhere in the results on the app where it says Export a PDF for your doctor.
I was hopeful but i can't find anywhere a way to export pdf
Open the Fitbit app on your phone - tap on the discover tab (on the bottom navigation bar) - tap on "Heart rhythm assessment" - "view results" - tap on one of the tests - "Export a PDF for your Doctor" - Continue the steps - When a notification pops up tap on "View it" - you should then be able to select where to save the PDF.
I've made a short video that may help you figure out the steps.
https://youtu.be/OBgUuQ9ATAQ
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
Thanks for the information. But, I am looking for a way to print or pdf Irregular Rhythm Notifications. The Recent Notifications show "Signs of atrial fibrillation" during my sleep.
@NoWord In that case it's not possible. I believe the irregular heart rate notifications are just there to serve as a prompt for the user to take a manual ECG. Obviously in your case that would be difficult if it's happening during sleep.
Nathan | UK
