11-01-2023 17:34
11-01-2023 17:34
Since update the battery percentage does not show up on app. Please bring back. Also please add a feature to track and input your weight.
11-01-2023 20:43
11-01-2023 20:43
Hi @Bigdaawg75 - this is a common request, you can add your voice in "The redesigned Fitbit app is rolling out!" topic in the appropriate iOS or Android app forums along with the other unhappy users where you will see more fully the issues.
Unfortunately it would seem likely you are stuck with this version officially. Though there may be some tweaks over time already mentioned there. This could take months to get this test version (requiring reworking) to anywhere near how the previous version was.
11-02-2023 04:48
11-02-2023 04:48
@Bigdaawg75 Fitbit listened to user feedback and announced it will bring back the battery percentage in this Community Blog post. Fitbit didn't give a time frame for the update. It sounds like you prefer seeing it on the app, but your battery percentage is in your Quick Settings when you swipe down on your screen.
You can track and log your weight on the Fitbit app. Tap on the pencil in the upper right and make sure the weight toggle in on. Logging manually is a little more streamlined in the app update. Tap on the green "+" sign, then the Manually log Weight option. You can't log your weight on the device screen.
Laurie | Maryland
