Can I manually change the water amount?
Is there a way to change the water amount on the quickadd menu?
My water bottle size does not match the only options shown.
Thank you in advance.
1 REPLY 1
@feagles24 Welcome to the Fitbit community!
Currently you can only add a custom measurement manually. I'd suggest posting your idea in the corresponding community forum:
Feature Suggestions
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
