07-29-2023 17:24
07-29-2023 17:24
I was reading through the forums that versa 4 isn't able to change and adjust the various exercises. Can you please fix this or update it. I had a versa 2 and because it broke, I got the 4. I would have gotten the 2 but it wasn't available any longer. Very frustrating that I'm not able to add the various exercises I use.
Please fix this.
Best Answer07-29-2023 20:17
07-29-2023 20:17
Hi @Monikutty - even though the Versa 2 is not available from Fitbit it should still be available in the shops and online.
Did you know if you are unhappy with the watch Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
07-30-2023 03:42
07-30-2023 03:42
@Monikutty The Versa 4 didn't remove any of the exercises that were on your Versa 2. Your Versa 2 had about 20 shortcuts and the Versa 4 has 40. It added things like kayaking, HIIT, core training, and others. The navigation is a little different. What activities did you do on your Versa 2 that you can't find?
Laurie | Maryland
Best Answer07-30-2023 06:55
07-30-2023 06:55
07-30-2023 07:19
07-30-2023 07:19
@Monikutty - you can't rearrange the shortcuts, they do it automatically with the most recentt coming to the top
Best Answer07-30-2023 08:20
07-30-2023 08:20
@Monikutty Here is some more information that might help you get more from your Versa 4.
As you use your Versa 4 more, you won't need to keep scrolling through that whole list, unless you have six or more favorites. 😉
Laurie | Maryland
07-30-2023 17:02
07-30-2023 17:02
Best Answer08-02-2023 05:05
08-02-2023 05:05
Thank you!
