Clock faces not working properly on my Versa 4
I’ve installed a traditional clock face on Versa 4 but it reverts to digital when watch is resting. How do I keep chosen clock face on constant display.
5 REPLIES 5
Welcome to the Fitbit community, @Rod64!
There are some clock faces that do have a dedicated AOD and there are some that haven't. If you select one of the latter, it will switch to the default digital clock face that Fitbit has implemented as an AOD.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
Hi @Rod64 - you probably can't keep the chosen face on all the time, even with Always On mode which uses more battery.
An alternative if you only want to see your chosen clock face, is to swipe the watch face down and turn off all icons.
Then when you look at the watch you will always see your chosen face
But if you properly set up a sleep schedule the display will be blank, so it doesn't wake you in the night, and in which case you will need to double tap it or press the button.
Thanks. That helps
Thanks. Good info
@Rod64 You're welcome!
Stefan
