11-16-2024
09:18
09:27
DavidFitbit
11-16-2024
09:18
09:27
DavidFitbit
My deep sleep information and REM sleeping information has disappeared and I only get a total sleep time and a wake time only. This happened overnight. Never happened before. Should I just stop paying $10 a month for not getting the product correctly?
Hi @vs1dcolor and @Stuckonone. I hope you're doing well. Thanks for stopping by. Allow me to help you with your sleep tracking.
If you received a sleep log, but it only includes your sleep pattern (which shows your time asleep, restless, and awake) check the following possible causes:
For more information about why you got your sleep pattern instead of sleep stages, tap or click the sleep record that shows your sleep pattern.
I hope these tips will be helpful for you !
Hi @vs1dcolor I appreciate you have taken your time to reply. I am glad to hear that everything is back to normal.
We remain at your disposition for any additional inquiry. Our main goal is to ensure an excellent experience with our Fitbit products and services.
Don't hesitate to come back to participate in the community. This is how the forums improve!
Best AnswerHi David. My oxygen rate and breathing rate haven't worked for the last 4 days and has worked perfectly for the last year. I went into the settings and the oxygen rate and breathing rate settings are not to be found anywhere in settings. Being that they're not in the settings, how can I retrieve that data now? I have rebooted, I have cleared the cache. 🤷
