Disable Versa 4 microphone
ANSWERED
How do I shut the microphone off on a Versa 4. I do not want it enabled.
1 BEST ANSWER
Accepted Solutions
@bwantsbasics   I disagree with @EstuardoFitbit’s answer.  I own a Sense 2 and it has the same operating system as your Versa 4.
  • Swipe down on the screen and tap on the Settings (gear) icon
  • Tap on Vibration & audio
  • Scroll down to Microphone and toggle it off
The Versa 4 doesn’t have snore and noise detection.
Laurie | Maryland
3 REPLIES 3
Hey there @bwantsbasics, welcome back to the Fitbit Community!
The mic is used for several things like calls and digital assistants. You can see how to turn it on by checking this article.
If your concerns come because of your data privacy, please take a look at this help page that provides all the information you should be aware of.
Laurie | Maryland
@LZeeW Thanks for the clarification!
I sincerely apologize for providing you with incorrect information, and your feedback is invaluable in helping me learn and grow. I edited my post so it can reflect the correct information.
I also marked your reply as the Best Answer so everyone can find the solution easily.
