Does Schedule mode (say 9p-5a) require Sleep or Do Not Disturb be turned on?
Also, I have 2 alarms set for 455a and 457a with Strong vibrations.
I noticed that I had the above schedule (9p-5a) with Sleep Mode also turned on and my alarms did go off but the defaulted to "light" vibration (instead of Strong) at 455a and 457a due to Sleep Mode being turned on?
Hi @Harry - Scheduling the watch into Sleep mode, also dims the display, turns on Do not disturb and turns off wrist wake and the screen. To get the screen to cime on you will need to push the button or double tap it.
The difference between Strong and Light is undetectable normally.
As regards the alarms, smart wake should still wake you but there seems to be problems with alarms on this watch. People claim they may or may not go off and perhaps can't be relied upon. Have a look in the forums.
I found on the Versa 2 and I felt it on this one (Versa 4) the vibration is a little stronger. Never used smart wake in the past and the alarms went off this morning.
