10-03-2022
17:40
08:42
10-03-2022
17:40
08:42
My question about the Versa 4: does it have movement reminders which tell you to get up and do 250 steps at 10 minutes before the hour (assuming you've not done the 250 by then)? Also, does it tell you once you've reached the 250 during those same 10 minutes? Thank you.
P.S. I recently bought an Inspire 3 for the movement reminders, but the signal is so weak I don't feel it, even when I'm expecting it. Is the Versa signal stronger?
10-03-2022 18:44
10-03-2022 18:44
Hi @Katusha page 31 of the user manual - click to read - says the strength of the vibration can be changed. That might be helpful for you if you don't always feel it. With my Luxe. it will vibrate at ten to the hour and then tell me xxx/250 on the screen so I can see how many steps towards 250 have been made. Once I've made those steps, it then tells me xx out of xx hourly activity.
10-03-2022 18:44
10-03-2022 18:44
10-04-2022 07:42
10-04-2022 07:42
I'm looking for the same answer I had a versa 2 which broke so bought a versa 4 but I can't see or find how many steps I've left to do, it only shows completed hours, very frustrating so would be interested if anyone can actually answer your question on the versa 4.
10-04-2022 09:29
10-04-2022 09:29
Hello, Odyssey13. Yes, I found that. I turned it to "strong" but unfortunately, it's still not strong enough to register. When I look at the screen, I see the reminder, so that part is working. Unfortunately, the signal strength even with "strong" is still to weak to register in my brain.
10-04-2022 09:30
10-04-2022 09:30
See the answer from Odyssey13 above. Perhaps it will work for you.
10-04-2022 09:34
10-04-2022 09:34
@Katusha sometimes when I'm doing something that takes my full attention, I can miss the vibration. If you find that happens to you, why not set an alarm for about fifteen minutes or less before the hour is up to remind you to get stepping. You can make eight alarms before you have to reset to do more, so that could be a possible fix for you. Do the alarms vibrate stronger for you? Also I've started doing more alarms on my phone, which is another possibility for you, if your phone is nearby and you can't feel the vibration.
