08-21-2025
18:36
19:16
DaniFitbit
08-21-2025
18:36
19:16
DaniFitbit
How do I view battery usage info on my fitbit versa 4 so I can see if a particular app or setting is making the battery run down a little faster than before? There's no battery info section under settings on my device, and I can't find anything in the fitbit app in my phone.
The last time this happened, the culprit was Always On Display, but that is turned off this time.
Hello @VersaCat2, it’s nice to see you around the Community Forums! Thanks for posting. Let me help you with your inquiry about the performance of the battery of your Versa 4.
For battery life issues we usually suggest some tips that apply in certain cases when battery consumption is affected by some features. See Extend your Fitbit device's battery life > Tips to extend your Fitbit device's battery life.
I invite you just to check these tips to see if the performance improves to an acceptable level.
Note: I need to point out that the Fitbit app does not have such a battery usage info. I appreciate your understanding. However, please share this idea on the Product Feedback board. Your suggestions can be upvoted by other users, making them more likely to be seen by our team.
