I've noticed in the past 2-3 days my fitbit Versa 4 is registering a much lower calorie count than usual. Sometimes I'll manual enter an activity/exercise on my phone (ios) and the calorie count immediately reflects that, then drops down to something much lower. What's going on???
Hi @lmneilson, it's great to see that you've visited the Fitbit Community!
Let me tell you that Fitbit devices estimate your calories burned based on your:
Tip: Some things to consider that may affect your device’s calorie burn estimate:
As a recommendation make sure that you wear your device correctly on top of your wrist. If you switch your device to your other wrist, update the Wrist setting in the Fitbit app. For more information, check How do I wear my Fitbit device?
Best AnswerThanks, but that doesn't explain why my daily count would suddenly be dramatically lower, when I'm doing the same exact amount/level of physical activity as I always have and tracked.
Hi again, nice to recieve your answer.
If after checking all the suggested biometric information in your device you are still recieving a lower calorie count I can recommend you to reach our support team since they have more tools to approach your specific case.
In the following link you can describe your situation, after that you are going to recieve some recommended articles and then you can select how you want to contact our support team. Support team.
