Fitbit versa 4 stuck and not charging
My versa 4 has been stuck on 55% battery level and has not been charging or decreasing upon usage.
It also stopped syncing with my phone 15+ hrs ago and is hanging a lot.
Fyi my versa has been quite pampered and never once fell on a hard surface and has been synced regularly.
I got this watch in May.
4 REPLIES 4
Welcome back to the Fitbit community, @Appy2006!
Sad to hear that you're having issues with your Versa 4.
Please make sure your iPhone is running iOS 15 or higher to be compatible with the current Fitbit app. As a first approach to hopefully get things fixed I'd suggest restarting your device by holding it's button for around 10 seconds until you'll see the Fitbit logo on it's display.
Next please give your Versa 4 a full charge. If it won't charge please have a closer look here:
How do I charge my Fitbit device?
Why isn't my Fitbit device's battery charging?
Finally, to solve your problem with your device not syncing, this should be helpful:
Why won't my Fitbit device sync?
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Thanks for replying.
I dont have an iPhone but own an android (IQOO Z5) I hope I can try the same things for android too.
Thanks again!
You're welcome, thanks for your fast reply, @Appy2006.
If your using a phone with Android, it should be running Android 9 or higher.
You can do the trouble shooting I've mentioned above on it as well.
Stefan
Okay thanks!
