10-12-2022
11:18
09:12
10-12-2022
11:18
09:12
Hi all,
Just upgraded from my old Charge 3 which was slowly dying to a Versa 4. I can't seem to add the activity of Workout to the device. On my account when I click on my watch I am presented with activities with goals, results etc and many of the activities are auto detection only. There doesn't seem to be an option for adding any of these to the watch so I can start and end tnem maually.
Thanks for any help
Best AnswerHello @bezzer23 and welcome to the Community. The Exercise app on the Versa 4 is very different from your Charge 3. You don't arrange and customize your exercise shortcuts on the mobile app. ALL of the exercise shortcuts are on the Exercise app on the device itself. Select the Exercise app on your Versa 4 and select from the list. When you select an exercise type, you will see a tiny "^" at the bottom of the screen. If you swipe up on that before you start, you will find other ways to customize each exercise that wasn't available on the Charge 3.
Since you are upgrading from the Charge 3, there is something you need to know. The Charge 3 gives active minutes and the Versa 4 gives active zone minutes. They are calculated very differently. They use different equations.
Laurie | Maryland
