How do I add my Rowing Machine distance to my daily distance?
Versa 4 gives data for heart rate and amount of time spent rowing, but I can't find any way to add the distance to the data on the app. Any advice?
2 REPLIES 2
Hi @AliceinKnox   I apologize if I misread your post.  It sounds like you want to add your rowing distance to your daily Distance.  You can't.  Your Fitbit distance is only from step based activity.
If this doesn't answer your question, can you ask it a different way?
Laurie | Maryland
@LZeeW, that was my question. Thank you for the answer, although it's disappointing. I have a distance goal, and I was hoping to track it with the Fitbit app rather than set up an Excel spreadsheet.
