01-20-2025
12:04
05:45
01-20-2025
12:04
05:45
Lost my Versa 4. It is in the house and has 95% charge. Bluetooth Finder was not specific to be of help. HELP!
Best Answer01-20-2025 20:59
01-20-2025 20:59
Hi @JoeRyan if you have your Versa 4 set up to notify you of calls and texts, try having someone call or text you. The vibrations might make some noise against an object so you can locate it. You'd need to be within 25 or 30 feet from your phone in order to sync or hear the vibration - give it a try.
