05-05-2025
16:12
03:49
05-05-2025
16:12
03:49
I had a reminder set to do something an I cannot find a way to clear the reminder so it does not pop up hourly.
Hi @cas124 - did you just ask Alexa to clear it or tap the tiny icon in the top right corner of the Alexa display
Of course if it is set elsewhere it might be necessary to undo it there, in the place you might have set it up to start with on the watch or in the Fitbit app depending on what type of reminder it is.
