How to turn off information when selecting a setting
Is it possible on Versa 4 to turn off the information that spears when you make a selection? For example every time you select sleep mode, the details pop up to advise it is sleep mode and a brief description of that setting, then you have to tap on the tick to select it. I would expect this in an initial set up of the device to guide you on each selection but not after that. Would love to turn the information off if it’s possible. Thanks.
1 REPLY 1
Hi @Beejs - the software is written that way on a Versa 4.
However you may be able to get around it by setting up a scheduled watch Sleep mode which sets it on and off automatically at certain times of the day before and after bed if you have an approximate routine.
It doesn't have to exact, it merely puts the watch into a dim, button wake only and do no disturb mode.
