02-15-2024
18:43
08:35
02-15-2024
18:43
08:35
I know these are both google products... But do they work with each other? Looked at tutorials, YouTube, message boards, etc... I can get app notifications like Google home, but Gmail, texts, phone calls do not work...
Hi @Christoxena - if you managed to install and sync the watch they should work fine together.
The issue you are having can come principally from 2 places.
First pull down on the watch face to get to Quick Settings and turn off all the icons, then restart the watch.
The new V4 Fitbit App can lose connection in which case you won't get any notifications even if the watch has been set up in the Fitbit App.
To make sure it is set up see How do I get notifications from my phone on my Fitbit device?
If the watch isn't currently syncing try the following and sync each time, toggle Bluetooth off/on, restart the watch, restart the phone, in the Fitbit App Device page Add more devices, select your watch and replace.
If you are using multiple devices turn them off and use just 1 phone and 1 watch.
Hope that helps.
