Is Versa 4 screen the same size as Versa 3?
ANSWERED
Is the Versa 4 screen the same size as the Versa 3?
1 BEST ANSWER
Accepted Solutions
Hi @Dster - the resolution should be the same 336 x 336 pixels.
You should note also if you are trying to choose between them that the new operating system in the Versa 4 has less features than the Versa 3 so it is not an upgrade.
2 REPLIES 2
Welcome back to the Fitbit community, @Dster!
Versa 3 and Versa 4 both have a display that's 1.58 inches in diagonal.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
