Hey yall,
I just upgraded my Versa 2 to a Versa 4 and I am not impressed. Before I send it back, I just want to make sure I'm not missing these features.
Am I able to log my weight using my watch? This was something I used a lot on my Versa 2 and I can't seem to figure out how to do it on the 4. Also, does the Versa 4 have a find your phone option?
TIA
@Khrazie There is no weight tile to add to the "today" screen like there was in previous models, so I don't think you can log your weight at all.
For the Find Phone, you can add it to your Fitbit by going into the Fitbit app > select your profile photo > select your Versa 4 > select Gallery > select Apps from the top of the screen > Find my Phone should on the list of options you can select and then install.
I've installed Find my Phone on the app, but can't find it on my Versa 4 watch? How do you get to it?
