12-04-2022 20:34
12-04-2022 20:34
I just received my new Versa 4 on 11/23, I charged it and updated it. Used it with no problems but that it says to wear it to bed to be able to see base temp(which I do every night, so already has been longer than the 3 nights it says) and the SpO2 does not show on my clock face, just a -.
I charged it today for the first time since the initial charge and now have a blank screen. Tried this to no avail
My phone says it cannot locate the Versa, but shows it is 100% charged. Thinking this was not a good purchase.
Best Answer12-05-2022 12:34
12-05-2022 12:34
Best Answer12-05-2022 10:10
12-05-2022 10:10
Hi @Emm2022 - have you tried restarting the phone and watch, they may not be syncing. Just in case see Why won't my Fitbit device sync?
Best Answer12-05-2022 11:30
12-05-2022 11:30
Yes, have done all they say. The app says it is stanching and it is showing my steps. When I restart- it will vibrate but the screen stays blank. If I change the clock face, it will vibrate but screen stays blank. My alarms go off, but the screen stays blank. The only thing I have not done is the factory reset mostly because I can’t get to settings on my watch to do so- and I really don’t want to lose all of my data, anyway, if I do not have to.
Best Answer12-05-2022 11:31
12-05-2022 11:31
Synching, not stanching- Auto-correct
12-05-2022 16:38
12-05-2022 16:38
That’s what I am thinking, too. Thanks for your time.
