I have had numerous syncing problems after updates that I've been able to resolve but NOTHING is working. I have:
Updated the Fitbit app
Restarted the Versa 4
Restarted the Android phone
Factory reset of Versa 4
Deleted Fitbit app cache
Deleted all Fitbit connections
The phone will NOT sync with the Versa to setup the watch.
So very frustrated.
Hi there @IreneRN! A warm welcome to the Fitbit Community!
Thank you so much for informing us about this situation and for all your efforts.
I suggest you try to do the following:
Best AnswerI discovered issues with my Versa 4 today when I woke up and it was 10minutes behind what my phone said and supposedly hadn't synced in 6 days. I had to delete my Versa 4 from the app and re-add it. I'm hoping it fixed the issue I was having. I believe I did lose some data but we'll see. I lost all the alarms I had set.
Best AnswerSo any are having issues with the versa 4 and the last updates. I finally reported to the better business bureau for all the problems with watch and app. They have been working into the abyss trying to fix multiple app problems. I keep getting a response that they are working on these problems.
The final word I got from Fitbit is since it's older than a year there's nothing they can do. They suggested I buy another Fitbit device - I think NOT.
Also what really stinks is they had me put it back to factory settings so now, without any Bluetooth, I can't even use it as a watch.
