02-12-2025 15:48
02-12-2025 15:48
I got my versa 4 not long ago I love it (goated upgrade from my versa 2), but I noticed that there is no music control. This was on my versa 4 and it was perfect for not having to pull my phone out of my pocket just a few inches to change my music, but now I have to do that with my versa 4. Is my watch just an update behind?
Best Answer02-12-2025 15:49
02-12-2025 15:49
Where it says “on my versa 4” I meant versa 2 btw
Best Answer02-12-2025 16:29
02-12-2025 16:29
Hi @DavidisCOOL. No, you aren’t an update behind. There are no music controls on the Versa 4.
Laurie | Maryland
Best Answer02-14-2025 19:20
02-14-2025 19:20
Hi @DavidisCOOL - the Versa 4 is not an upgrade to the Versa 2 as it doesn't have all the features a Versa 2 has, lack of Music controls being one of them.
If you are in the return period that may be a solution and replace with another Versa 2 or a Versa 3 (though some clocks or apps may not have been ported, depending on what you used).
Best Answer02-19-2025 14:04
02-19-2025 14:04
The Versa 4 really does feel like a downgrade.
