12-26-2023
08:37
13:57
ManuFitbit
12-26-2023
08:37
13:57
ManuFitbit
Versa 4 has recorded sleep stages but I have not recieved a sleep score. All the “to-do” suggestions have been done correctly and still no score. Very frustrating My device is over a year old and this is the first time it has happened two nights in a row
Moderator edit: clarified subject.
Hi @JeanetteT821. It's good to see you participating in the community.
Thank you for taking the time to share the experience with Versa 4 and for all the steps that you already did in order to fix it. I'm sorry to know about the inconvenience.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 4 may need some days to collect some information (particularly regarding heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same situation.
In case the inconvenience is related to the Fitbit app, please try the following as well:
