11-04-2022
10:17
08:08
11-04-2022
10:17
08:08
Hi,
I've been a loyal user since Fitbit first came out, but I'm so disappointed with the Versa series. I had a Versa 3 that quit doing anything except being a pedometer, so I decided to replace it (it was a whopping two years old). I debated for quite a bit between the Versa 4 and the Apple watch. I wish I'd chosen differently. I can't get any notifications without manually syncing, and often not even then. I've done all of the steps with Bluetooth, reset, restart, background app refresh on, even leaving the fitbit app actively running on screen, my notifications can't be more on. I guess at this point I'm stuck with a fancy pedometer, again, unless Fitbit solves this issue.
Hi there, @k10pinter. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 4 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
While reading your posts above, I was wondering if you did remove your old Versa 3 from your Fitbit account and phone's Bluetooth settings?
It seems that your Versa 4 cannot connect properly to your Fitbit app since you haven't yet forgotten the connection between your old watch and the phone's Bluetooth which would explain the issues you're running into. With that said, try the steps below:
Hope that helps.
Best AnswerI have the same issue with message notifications not coming through.
I do receive calendar alerts.
I have tried all the fixes suggested.
The first Versa 4 I bought had a defective battery and I managed to get it replaced. I had assumed the lack of notifications was somehow linked to this fault but clearly not.
Super annoying. 😢
