08-05-2023
19:14
04:44
08-05-2023
19:14
04:44
I can not get text messages, or answer the phone or send emails or use my Alexa
Best Answer08-05-2023 21:09
08-05-2023 21:09
Hi @Sugarlipss - some simple things to try
If the last one isn't working or you are still not getting message notifications try
Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on.
Restart the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Login and wait for any pair, link or Fixit prompts and sync.
08-07-2023 03:09 - edited 08-07-2023 03:10
Welcome to the Fitbit community, @Sugarlipss!
Concerning Alexa on your Versa 4 I'd like to point out that you need an Amazon account use Alexa on your device. If you don't have one, you can register here:
Next please follow the instructions provided here to set up Alexa on your device:
How do I use a voice assistant on my Fitbit smartwatch?
To set up your Versa 4 for receiving on-wrist calls, I'd suggest having a closer look here to see how that's done:
How do I take on-wrist phone calls with my Fitbit smartwatch?
This should be good start to start to overcome first hurdles on the points you mentioned. If you do have any questions about details, do not hesitate to come back.
08-07-2023 04:46
08-07-2023 04:46
Hi there, @Sugarlipss. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
If the steps recommend by @Guy_ and @Talahthas don't make any changes, please try the following:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
