Paths
Is it possible to customize my paths on the main screen when I look at my Fitbit versa 4?
I exercise often and don’t care to see how many “active minutes” I have. I would rather see how many calories I have eaten, water drank, etc. Is it possible to customize this, and if so, how?
2 REPLIES 2
Hello @Tdotshaney and welcome to the Community.  Can you please clarify some details?  Are you asking about customizing your mobile app screen or your device screen?  If you want to customize the app screen, I recommend using the Custom Focus option.  Tap on the pencil icon in the upper right, choose Custom focus and you can choose the four metrics that are at the top of the screen.
Can you give more details if you want to customize the Versa 4 screens?
Laurie | Maryland
Hi @Tdotshaney h in addition to what @LZeeW  provided, note it is possible to install other clock faces from the Gallery tile of the Fitbit App which show better what you want to see.
It may not be easy to find one which shows what you want but try entering the criteria when searching through them.
