11-26-2023 10:57
11-26-2023 10:57
I just bought a fitbit versa 4 today, will arrive ... i dont know when. Anyway i break out with wearing the bands that come with thesw.
My last fitbit versa 1 fried bwcause water got into it when i was washing my hands (no damage or anything should have caused that) recently. Had it since 2018. Anyway i have an offical fitbit metal band that i purchased back then with it. Will it fit the fitbit versa 4?
Best Answer11-26-2023 11:19
11-26-2023 11:19
@JT1985 I’m sorry, but they won’t fit. The original Versa bands use a pin system. The Versa 4 has a quick release system.
Laurie | Maryland
11-26-2023 13:08
11-26-2023 13:08
Send a picture please because the pins i have are called quick release.
Best Answer11-26-2023 19:44
11-26-2023 19:51
11-26-2023 19:51
Its not the original band its bought of fitbit a metal band before they stopped selling them.
Best Answer11-26-2023 20:01
11-27-2023 04:28 - edited 11-27-2023 09:26
@JT1985 I never tried the Fitbit metal band on my Versa, but all of my Versa bands use a spring loaded metal pin. Here is a link to the Wear Versa 4 chapter of the Versa 4 manual. You can see that the quick release latch is a very different design, making the bands from the different models incompatible. You can also browse the rest of the manual to see the differences between the two models.
Laurie | Maryland
Best Answer11-27-2023 09:16
11-27-2023 09:16
So where can I get a metal band that matches this thats not s feminine look?
11-27-2023 09:28
11-27-2023 09:28
@JT1985 From a third party site like Amazon or eBay.
Laurie | Maryland
Best Answer11-27-2023 10:06
11-27-2023 10:06
Why did fitbit stop producing metal bands after versa 2?
Best Answer11-27-2023 11:06
11-27-2023 11:06
@JT1985 Fitbit doesn't explain why a style might be made for one model, but not a later model. It could be something as simple as poor sales of that design.
Laurie | Maryland
