10-27-2023
10:27
11:45
10-27-2023
10:27
11:45
When I get a text on my Versa 4, I don't see any option to respond, all I have is OPEN or CLEAR. I use CHOMP sms app on my Android phone, is that the issue? I wasn't sure if you had to be using a specific SMS app on your phone for it to work.
Update: Never mind everyone, I discovered CHOMP is not supported to respond via my Versa $
Best Answer10-27-2023 11:44
10-27-2023 11:44
Hi there, @SunsetRunner. Thanks for stopping by in the Fitbit Community Forums. I appreciate you've taken the time to find the answer to your inquiry, thanks for updating your post.
Would you mind trying the tips and recommendations another user shared here?
Hopefully that does the trick for you too!
