Solved - Versa 4 wouldn't start correctely after factory reset
My fitbit app was not able to update my Versa 4, even if an update was available. Nothing happened when pressing update button. In a search for a solution, I did a factory reset of the Versa 4. However, after restart, only instructions how to install fitbit app were present, not the regular Versa 4 OS. Redoing factory reset didn't help. I managed however to fix it with the following steps:
- I did an iOS for iPhone16 Pro update and a fitbit app update to their current versions on 2016-Jan-15.
- I tried to add in the fitbit app a new Versa 4 device. That asked to replace the old Versa 4 device. I choosed yes, but the replacement failed. However, this action removed the old device from the app.
- I did a Versa 4 reset by pushing the button for ~ 10 s, until the fitbit logo appears. This is not the factory reset, just a simple reset. Again the instructions (and the language choice) appear on Versa 4, but not the OS.
- I added a new Versa 4 in the app. This time it worked and it also gave the option to update Versa 4 from inside the app. I started the update and, after about 10 min, the update completed succesfuly. That produced a fully functional and updated Versa 4.
Moderator edit: clarified subject.
1 REPLY 1
A warm welcome to the community forums @iLivioo
Thank you for sharing the details regarding the difficulty that you experienced with Versa 4.
Thank you for providing all this information about how did you get it solved. I'm sure that the steps are usefull and are going to help other users having the same or similar situation.
I'd like to invite you to visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
Have a nice day.
