Still having issues with the SpO2 readings on my Versa 4. I rarely had the same problem with my Versa 3
I tried all the tips and tricks including:
Sync just before bed, and immediately after waking
Turning Bluetooth on and off
Changing clock faces
Uninstalling and re-installing the app
Wearing the band another notch tighter and up my wrist higher
I have even shaved my wrist where the watch sits for better contact with my skin
Sleep metrics say I'm averaging 4-6 hrs a night of measurable rest
If I do a full reset on the watch, reinstall the app, reset Bluetooth, and follow every other instruction it will work for a couple days, then it quits. Another full reset has the same results. Not finding any other suggestions
Every other app/function on the watch works just fine
Help. I like the watch, but oxygen saturation was a primary function in the decision to buy it. If I can't get any level of consistency necessity will require me dumping it.
Thanks
