02-25-2025
13:01
09:40
DavidFitbit
02-25-2025
13:01
09:40
DavidFitbit
On device, the alarms do not seem to work. When I access the app and set the time, it flashes a couple of times but the alarm never goes off.
I'm also not able to see any alarm app on the iPhone. I can see Alarms installed on the iPhone app but no way to manage them.
Any suggestions? I’ve updated and restarted a couple of times. This is Versa4, btw.
Moderator edit: merged reply
02-26-2025 11:41
02-26-2025 11:41
Hi @Rabbit090, welcome to the Fitbit Community! It's great to have you here!
Let me help you managing your alarms.
As you may have already noticed, For Versa 4, alarms are set on the device itself. This being said, make sure you follow the instructions below to set an alarm on your Versa 4:
02-26-2025 12:26
02-26-2025 12:26
Thanks very much. That worked. Previously when I tapped it, it simply changed the time again. Perhaps I didn’t give it enough time.
