05-17-2023
11:41
14:55
ManuFitbit
05-17-2023
11:41
14:55
ManuFitbit
Moderator edit: clarified subject.
20:04
16:55
05-17-2023
20:04
16:55
Hi @Jaah52 - the Versa 3 is more feature rich and cheaper, besides what you use now on the 3 may not be found on the 4, for instance not all clock faces found on the 3 are available on the 4 and NO additional apps can be added.
What you can see and do on the Versa 4 is a lot more limited and it has a different less refined user interface, which has no Google Assistant or any music ability at all.
