08-28-2024 05:29
08-28-2024 05:29
I’ve had a suspicion my Versa 4 was under recording distance for a while. I’m training for a 26mile walk for charity and today completed the longest training walk so far. Due to my concerns I got 3 others to track using their Fitbit, and Apple Watches. We walked 18 miles! My Versa 4 recorded…12!!!!! Absolutely awful for a device supposedly designed to record distance. What is wrong with it? Is this just a known fault? I’ve been a Fitbit customer for years but am now considering other options 😞
08-28-2024 05:38
08-28-2024 05:38
I should have added it is recording steps, they came in at over 30K, but not accurate with the distance
Best Answer08-28-2024 06:16
08-28-2024 06:16
@LeanderD There is a glitch with distance currently being investigated. The workaround for this is to enter your stride length manually.
If you're on iOS, you might have to scroll down far enough to see the Stride Length option. Android settings might look a little different.
08-28-2024 07:43
08-28-2024 07:43
I wear my Versa 4 and Apple Watch 9 and they both record the same distance, average heart rate, etc. There are minor differences in calories burned.
Best Answer08-28-2024 08:08
08-28-2024 08:08
Thanks, this may be a stupid question but how do I know what my stride length is?! 🙈 also, will that adjust the distance walked today already or only distance going forward? Thanks ☺️
Best Answer08-28-2024 08:17
08-28-2024 08:17
I have just tried this using various stride lengths and the maximum it changes to is 1.5 miles more taking it from 12 to 13.57. I walked 18 miles so this is still completely wrong 😞
Best Answer08-28-2024 08:44
08-28-2024 08:44
Hmm, I have never adjusted my stride length. Where do you do that ?
Best Answer08-28-2024 11:25 - edited 08-28-2024 11:26
@LeanderD From this Help Article, here is how Fitbit says to measure your stride length:
I wonder if your Versa 4 just had a bad connection to the GPS signal. Mine will be slightly off (never that many miles though) if the connection isn't great. There is an update for the Versa 4 that is supposed to improve the GPS capabilities. What version is your Versa 4 on? The newest version is 210.26. You can find this by tapping on your Versa 4 icon in the app.
Best Answer08-28-2024 23:11
08-28-2024 23:11
If it was a one off I’d accept it might have been a bad connection but it’s happening every time and I had another Fitbit and two Apple wearers with me on same provider so it just doesn’t make sense. So frustrated, when training for something you need something reliable, I’m looking into alternatives as it just feels like Fitbit can’t deliver 😞
