01-03-2025
08:09
09:12
DavidFitbit
01-03-2025
08:09
09:12
DavidFitbit
My verse 4 charger is not charging my watch . Is it possible to get a replacement?
Best AnswerHi, @MeetaC! If you're in the warranty window, you can contact Google Support. Otherwise, they sell the charging cable on their store or you can find third party cables out there.
MakMak | Community Council
Hi @MakMak and welcome @MeetaC to the Fitbit Community! It's great to have you here!
I'm glad to help you with the charging issues you are experiencing.
In my opinion, i suggest that you take a look at our help article Why isn't my Fitbit device's battery charging? and see if those tips are helpful.
If you are 100% sure the charging cable is the source of the problem and you are within the limited warranty period, you may proceed as @MakMak suggested. To contact our tech support.
Happy sporty 2025!
