08-10-2024 07:05
08-10-2024 07:05
So I have had this for a grand total of 4 day and have had multiple problems. The biggest of which it seems to restart itself constantly. At least, I am getting the blue diamond of death on a regular basis. The particularly happens when I try to track exercise. I select the correct exercise and choose start. When I try to check my progress, it seems to automatically restart and any time I've spent on that exercise is wiped out. Exactly what good is a fitness tracker that won't track workouts?!?! I have rebooted multiple times with no luck in correcting the problem.
Also, had major troubles just setting the thing up. I had a Versa 2 for 5 years and never had a problem with it. You would think by now any new versions would be better than previous ones.
Best Answer08-10-2024 07:49
08-10-2024 07:49
@AmyScott73 Have you tried doing a total factory reset to see if that fixes it? It's in the Settings options on the device.
Best Answer08-11-2024 11:38
08-11-2024 11:38
