03-15-2023
12:12
04:20
03-15-2023
12:12
04:20
App always shows battery full for my versa 4 it so not syncing properly with android app.
Best Answer03-16-2023 04:24 - edited 06-03-2023 11:16
Hi there, @satheeshboopath. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
Regarding the battery level on the Fitbit app, note that it updates every time you sync. That means that if your watch hasn't synced yet, your app will still show the battery percentage of the last sync. Since your Versa 4 is not syncing, please follow @Guy_'s tips and recommendations.
If the issue persists after trying the above, please try the following:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer03-15-2023 22:22
03-15-2023 22:22
Hi @satheeshboopath - you can see the real battery level, in Quick Settings, if you pull down on the watch face.
For the syncing issue, see Why won't my Fitbit device sync?
Often restarting the watch helps How do I restart my Fitbit device?
Also a logout of the Fitbit App and swipe off the active window and clear storage cache and force stop it and phone restart helps.
Login and wait for any pair and link prompts and sync.
