Versa 4 - Set Alarm
ANSWERED
I have an alarm set on my versa 4 and want to change it but can't find where to do it.
Moderator edit:  updated subject for clarity
1 BEST ANSWER
Accepted Solutions
Welcome to the Fitbit community, @Cath82!
To set or change alarms on your Versa 4 just press the side button to get access to the apps installed on your device. Scroll until you find the Alarms app and tap on it to open.
If however you've set an alarm using Alexa, tap on the Alexa app instead. You'll find your reminders by tapping on the small clock icon in the upper right corner of the Alexa app.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
1 REPLY 1
Stefan
