10-20-2025
14:40
15:14
10-20-2025
14:40
15:14
This may have been discussed a while ago.
I've has my Versa 4 for nearly 2 years and I'm finding I'm charging it every other day.
Yes, I've turned off this and that but it still gives flat very quickly.
Any ideas?
Hi there, @Wilberforce. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Versa 4 keeps draining. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend making sure that your phone's software version is updated. For more information, refer to Check & update your Android version or Update your iPhone or iPad
If you haven't done so yet, please try all tips and recommendations provided here Can I extend my Fitbit device's battery life?
Best AnswerHi,
I've checked things out and all seems as it should be.
Last night I went to bed with the watch showing 72%, when I woke, it was showing 40%. A couple of hours later I went out but the watch had 'died' totally, so I just left it behind charging.
I tried to switch it on, but nothing happened for several minutes. Then the screen showed the fitbit symbol on a black background for a moment then went to the opposite. A pale blue background and a black fitbit image. This went on for a minute or so, then nothing.
I tried to power it on as per guidance and for the last half hour, every 5 -6 seconds, the fitbit image appears then goes out after 5-6 seconds.
Is it 'Goosed' as we say, or knackered in other words?
Not good after less than 2 years usage. And when I say usage, I wouldn't call it to be excessive.
@Wilberforce Thanks for getting back to me and for the details provided in your last post.
To better assist you, I suggest reaching out to our Support Team who will be able to take a closer look into this issue and provide further help. This form is only meant for you to use. Click here to get access to it.
Maria,
I had a session last night on the fitbit chat and I think we are getting the issue resolved.
The mad thing is, that a friend of my wife's has just been visiting us and she also has a Versa 4 and guess what? Since a recent update, her battery is also draining much more quickly than it was.
Thanks.
W. Force.
Result.
Thanks Fitbit.
They asked me to send my Versa 4 using a label they sent me. Two days later, I got a replacement.
Best Answer@MarreFitbit As I now have a new fitbit Versa 4. I note that the version under System is shown as 61.20001.194.86. I have no idea what the version was on my previous Versa 4, but actually wonder I had updated that watch and therefore wonder if this caused the issues I had. I note elsewhere that there is reference to a new version.
I note also that the fitbit app tells me there is a new firmware update available.
I'd like your thoughts on how to progress this. Will I end up with the same battery issue as I had previously?
Best Answer@MarreFitbit Hi, maybe you haven't seen my previous posting.
Any thoughts?
I note that with the current software version as posted, I am getting over a week, maybe into a 9th day of battery life.
