02-17-2023
18:16
07:33
02-17-2023
18:16
07:33
i just got a versa 4 literally 2 days ago. the first day i charged it to about 70% so i could wear it at work, and it died by the end of the night. figured i just didn’t charge it enough. so i charged it to 100% last night and put it on and it immediately went to 80%? i slept with it on and woke up in the morning and it was at 60ish%. wore it all day today and it was dead by the time i got home from work (8 hour shift). i thought the battery life was supposed to be much longer than that? i had a versa 2 for about 2 & 1/2 almost 3 years and the battery lasted almost a week before it started to die. has anyone else had this problem? i don’t have always on display on, either.
Hi @sutleasti - that doesn't seem normal. You should get the same battery life as the versa 2.
Check your exercises to make sure it hasn't registered any, because this has on board GPS which will only last 5 hours anf that could exhaust the battery fast, otherwise it should last without AOD.
It has been possible that a sync issue will also exhaust the battery. To check turn off the Bluetooth on the phone and aim for a 16% fall in battery per day.
