08-07-2023
08:44
04:41
08-07-2023
08:44
04:41
All of a sudden my versa 4 is unable to hold a charge. it used to hold for about 5 days then one day it changed and I’m lucky if it lasts 3. I don’t have it on “always on display” I rarely use gps, literally nothing has changed except my Fitbit has decided it doesn’t wish to hold a charge. The thing isn’t even a year old and shouldn’t be acting like this…
Best Answer08-07-2023 21:04
08-07-2023 21:04
Hi @Tess963 - if the watch is having syncing issues following a Fitbit App update it can consume more battery.
But first hold the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
It can be a good idea to restart the phone too.
If this doesn't help try turning off the phone's Bluetooth when not syncing.
The watch can still be replaced under warranty if nothing helps.
Best Answer08-08-2023 04:44
08-08-2023 04:44
Hi there, @Tess963. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 4.
To better assist you, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
If none of the above works, please follow @Guy_'s advice and chat with us online or give us a call. Click here to get connected.
Best Answer08-14-2023 07:10
08-14-2023 07:10
Thanks, I will check it.
