Hi there @Smitty63, welcome back to the community
Thank you for reporting us about the inconvenience you are facing. Please be aware that certain functions may have an effect on how long your device's battery lasts. The Always On Display is one of the features I describe. With some clock faces, you may use this option to keep the display on always.
Please take a look at this article, which lists every feature I mentioned.
Hi @Smitty63 - a sudden drop like that can be a one off, try restarting the watch and see if it repeats, it may well not.
Also only use the on watch battery level to check, on the Quick Settings view, pull down in the watch face to get a consistent battery level view.
In some instances it can be a phone problem so try turning off Bluetooth for the duration to see if it changes battery usage on the watch, if the issue persists.
