09-24-2024
08:15
12:07
09-24-2024
08:15
12:07
My screen is blank. The rest of the watch works- still getting buzz notifications and it is syncing with the app. Any suggestions for a re- boot or is it RIP?
Hi there, @Laurie655. Thanks for bringing this to my attention. I'm sorry to hear that the screen of your Versa 4 is blank. I understand your concern, I will do my best to help you!
If you haven't done so yet, please try the steps below:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best AnswerThanks for the quick reply. Unfortunately your suggestions did not fix the problem. Can’t wear a watch with a blank face so it’s RIP Fitbit! I am going to buy a Garmin hybrid smart watch instead.
