My Versa 4 has been fine until today. I put it on my charging block to charge but when I went back the battery had been draining instead of charging. So I moved it to a powered plug. When I returned, the display said your Versa 4 is too hot to charge properly. Cool it before continuing to charge. I removed the watch from the charger and it was at 99% so I thought ok. But it rapidly discharged within an hour. It had cooled so I placed it on charge again but, shortly after the display came up with the same message. The watch felt v warm. I charged the watch last week using the same power plug with no issues. It has cooled again but the battery is fully drained again. Should I try resetting it or has something gone wrong with the device. I've only had it a few months.
Thanks. I thought that might be the case. It should still be under warranty. Bought it direct so I'll find the order receipt and contact them.
