06-25-2025
14:29
20:02
ManuFitbit
06-25-2025
14:29
20:02
ManuFitbit
I think my Fitbit accidentally got stuck in an update process and now is frozen on the blue Fitbit logo.
While plugged into the charger: When I try to initiate the update in the app again while the watch is on the charger, it fails and says to try again later. Here are other things I have tried:
1) Removed the Fitbit from Bluetooth known devices and added it back in (now currently noted as connected, but only while connected to the charger)
2) Tried to change the clock face in the app to restart the clock screen, but this did not work despite it has updated the clock face visual in the app on my phone
3) Reinitiated the hardware update in the app, but this fails every time.
4) I saw a note on the Support community telling you to take the device off the charger and try and force restart, but when I remove the device from the charger, I get a black screen. When I try and force restart, it shows a flashing blue outlined logo for a few flashes and then a red X. Then goes back to a blank screen.
Do you have any other tricks I could try? I've now not been able to use my device for over a week and I'm having withdrawals! 😞 Is there a way to check if the device isn't charging properly and/or if there is an issue with the device sync?
Moderator edit: clarified subject.
Good to see you around @LoloS7.
Thank you for the detailed information shared with me regarding this difficulty that you are experiencing with Versa 4. Sorry to know the situation and thank you for trying to fix it on your own.
Before considering other options I'd like to ask you follow the steps listed in this help article in order to get the device charging.
Best AnswerHi Manu,
Thanks for sharing over that article. My device lights up with the Fitbit logo when I plug it into the wall, but there's no real way for me to check if it's charging given the screen is frozen on the logo. I do know the last time the watch synced was June 9th from looking in the app analytics, however, so clearly something is up regarding the UX. Any other tips?
Thanks!
Welcome back @LoloS7.
Thank you for the information, the details provided and for trying to get it solved.
While reviewing your information I've been informed that you already contacted the Support Team for further assistance with this. In this case, they will let you know how to proceed. Please keep in contact with them and take a look at your inbox.
